HAL.Card.IOCardWrongForMode
Description
The type of I/O card in the specified I/O slot cannot be used with the named Fabric Mode.
Remedy
Either remove the I/O card from the switch, disable it, or upgrade the fabric modules.
Severity
Warning
Message Text
The %cardTypeStr% card in %slotName% is not usable in Fabric Mode %fabModeStr%. Please disable the slot, remove the %cardTypeStr% card, or upgrade the fabric modules.
Message Parameters
Name Type
cardTypeStr String
slotName String
fabModeStr String
Applicable Platforms
